1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
Battery stopped charging while plugged in
Hi I need some help !
I replaced my battery then charged it. After a while the fans started to be really loud so I moved my laptop from the couch to a table. The fans were less loud. After another while, the light was still orange and I started wondering why it was taking so long. It had been over two hours. I wanted to see how many percent the battery was at. I turned on the laptop, it showed 83% then the light turned green and it stopped charging while it was still plugged in. I kept it plugged, I turned it off. Waited for a few minutes. Then turned it back on. Same green light, same charging stopped.
I am worried. Can you help me ?
I am leaving it plugged in and turned off but the light is still green.
Thanks,
Nathalie
Add a comment
1 Answer
The charging logic has two inputs to prevent over charging, thermal and voltage sensors. As the battery is 83% charged and the MagSafe cord LED is Green tells me the system is just in a wait state for the battery temp to drop. To be honest I don't let my systems charge beyond ~80% I use a third party app to do this as your battery will last longer.
How about installing a more informative tool to monitor your systems battery condition. I find CoconutBattery as one of the better.
Add a comment
Add your answer
Nathalie will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 135
