Black Shadow on the screen
Hello,
I have a black shadow on the tv screen, how do I remove it? Thank you!
Add a comment
1 Answer
Most Helpful Answer
Hi @davidlynch94469
Without seeing what it looks like it sounds like there's a faulty LED (or LEDs) used for the backlighting of the screen.
The TV model you selected for your question is an edge lit TV i.e. LED backlight strips are on the edge of the screen and not across the screen.
Here's a video that shows how to replace the backlight strips for your model TV.
If it is only a few LEDs that have gone faulty it is better and easier to replace the entire strip rather than the individual LEDs as there may be a slight colour difference due to the age difference between the new and existing LEDs plus if some have failed then the others may not be that far behind in failing also.
Search online for UE50NU7455UXXC replacement LED strips to find suppliers that suit you best.
Score 1
Add a comment
Add your answer
David Lynch will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 220
