Como arreglar el tactil
Mi tactil no funciona
Translation Spanish - English
How to fix the touchscreen
My touchscreen isn't working
@edisonsoto sounds like a failed touch screen. It is part of the display assembly. That means you will need to have to replace the complete display assembly. Since iFixit dos not yet have a specific guide for that, use something like this video Replacement screens are readily available at many online stores. Purchase one that has the midframe already attached to it. That will make this task a lot easier.
Should a new display not fix this issue, then you are having trouble with the main board. Could be the Touch IC circuitry. For that you will need the schematic, the board view as well as the proper tools to do a board level repair. Start with a new display.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@edisonsoto parece que se trata de una pantalla táctil defectuosa. Forma parte del conjunto de la pantalla. Eso significa que tendrás que sustituir todo el conjunto de la pantalla. Dado que iFixit aún no dispone de una guía específica para ello, utiliza algo como este vídeo. Las pantallas de repuesto están disponibles en muchas tiendas online. Compra una que ya tenga el marco central incorporado. Eso facilitará mucho la tarea.
Si una nueva pantalla no soluciona el problema, entonces tienes un problema con la placa principal. Podría ser el circuito Touch IC. Para eso necesitarás el esquema, la vista de la placa y las herramientas adecuadas para realizar una reparación a nivel de placa. Empieza con una nueva pantalla.
Mientras trabajas en tu teléfono, toma muchas fotos. Una vez que hayas terminado, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga un dispositivo con los mismos problemas que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit te lo agradecerá.
¡La reparación es la guerra contra la entropía!
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 169
