Repair guides and support for the laptop line of Acer's Extensa series for office and business use.
wifi switch not working
my wifi front switch not working
Add a comment
1 Answer
The Wi-Fi switch on Acer Extensa laptops is only a hardware toggle. If it doesn’t work, check these points:
1. BIOS setting – Enter BIOS (F2 on boot) and confirm wireless is enabled.
2. Function key – Some models need Fn + F3 (or the key with an antenna icon) in addition to the physical switch.
3. Drivers – In Windows, check Device Manager → Network adapters. If the wireless card is disabled, right-click → Enable. If missing, reinstall the driver from Acer’s support site.
4. Power management – In Device Manager, open the Wi-Fi card properties → Power Management → uncheck “Allow the computer to turn off this device.”
5. Switch failure – If the physical slider is broken, you can bypass it in software by forcing the Wi-Fi card enabled in Device Manager or BIOS. Hardware repair would require replacing or bridging the switch contacts.
Add a comment
Add your answer
AYINDE SAMUEL will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 154
