A programmable brewing machine by Keurig. This coffee maker uses K-Cup Pods and K-Carafe Pods to brew a variety of hot and cold drinks. Model Number: K2.0-400 Serial Number: 401.0200.1410931
What is causing a water under pressure error?
What needs to be fixed/replaced to solve this issue ? thanks
Add a comment
1 Answer
@slevinkele94271 your Keurig gives you that error when it can't force the hot water through the pods. Start by cleaning the opening of the top and bottom needle puncture valves. check this guide How to open and clean Keurig Coffee Maker for that . Also not the same model it's the same idea.
Add a comment
Add your answer
slevin kelevra will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 32
All Time: 161
