Ultraportable 13" laptop computer released by Dell in 2019.
DCGH8 battery recharge cycle
I just bought battery from ifixit for my Dell XPS 13 9380. I was wondering how many full recharge cycles does it have. The OEM is supposed to have 300-500 cycles before the capacity drops to 80%. Is the ifixit battery comparable?
Add a comment
1 Answer
Most Helpful Answer
@mabindrar you can check the cycle count of your battery by using Dell's built-in diagnostics. Press F12 at startup, select Diagnostics, go to the System Info > Health tab. See what it tells you about the cycle count.
You can also run that in Windows by using the command prompt:
  1. Open the Run window: Press the Windows key + R on your keyboard simultaneously.
  2. Open Command Prompt: Type cmd into the Run window and press Enter or click OK.
  3. Run the command: In the Command Prompt window, type powercfg /batteryreport and press Enter.
  4. Find the report: A file path will be shown in the Command Prompt; this is where the report is saved.
  5. View the report: Copy this path and paste it into your web browser or File Explorer to open the HTML file containing your battery cycle count and other information.
from here
As for the battery being comparable, that is something only the service staff at iFixit can answer but I am certain that it is equal to or better than what you would get anywhere else.
"Our aftermarket replacement batteries lead the industry in quality and reliability. Rest assured you're getting the best part money can buy.
  • 0-Cycle - Each cell is brand new and has never been used.
  • Rigorous Testing - Every single battery cell is tested to ensure it meets our specification.
  • No Shady Business - We don’t modify the battery’s capacity or cycle count information to make it look better than it actually is.
  • We’ve Got Your Back - 1 Year Guarantee - We spend countless hours making sure we provide the best batteries you can get. We are uncompromising when it comes to safety and performance."
Score 1
Add a comment
Add your answer
Mabindra R will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 185
