The fourth-generation Ram pickup truck (called Dodge Ram until 2010) was introduced in 2008 for the 2009 model year and sold as the Dodge Ram 1500. The 2500, 3500, 4500, and 5500 models were later added to the lineup.
Wheel hub Bearing repair
  • How do I safely repair wheel bearing and hub
Add a comment
1 Answer
This is a simple job, I did mine recently. Raise and set truck on jack stands, unbolt the caliper and use a wire to hold it up and keep strain off line,remove the caliper retaining bracket 22mm I believe. Once those 2 bolts are out there’s 3 bolts from behind that hold the hub assembly in place. Before removing the bolts, disconnect the abs wire up at the connector on the chassis then proceed with the bolts. U might need to persuade it with a hammer if you’re up north. If it’s 4x4 you’ll need to undo the axle nut. Reverse the process and should take under 2 hours tops. I did mine in an hour and a half and have a medical condition that affects my breathing and I used all hand tools. Just work safe!
Add a comment
Add your answer
Raven Buffalo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 79
