Repair guides, disassembly, and troubleshooting information for the second-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB of storage. Released in March 2011. Identified by model number A1395 and EMC 2415. Repairs require the use of heat and careful prying.
Removing digitizer glue residue
I have an iPad2 on which the digitizer was completely shattered and had to be removed piece by piece. I've done this but there is a lot of glue residue left all around the edge of the device. I have the 3M glue pads and I'm ready to install the new digitizer, but I want to remove all the old glue first, some of which still has somevery fine glass shards stuck to it. Is there a solvent I can use to achive this without damaging the device? If not, is there a way to do this so that I've got a clean surface to apply the new glue pads to?
Score 2
Add a comment
Chosen Solution
You can use a spudger (metal or plastic) to scrape it off. A putty knife, or any flat scraping utensil will work also. Just go slowly and work it bit by bit. The glue will ball up and can be peeled off. If you want to loosen it some, take a hairdryer and heat up the glue. That will get it to soften and release. Just be careful to avoid blowing heat directly onto the LCD, stick to the edges.
1 Comment:
Try some hand sanitizer with a soft cleaning cloth.
by
Add a comment
Most Helpful Answer
CHARCOAL LIGHTER FLUID
Not sure if this will work for iPads but I use it for laptop digitizer bezels and it works for me.
Pour some lighter fluid into a small glass. Not much, just enough to dip a Q-tip.
Dip the Q-tip into the fluid and gently coat the adhesive and let it soak in for a few minutes.
Use the dipped Q-tip to remove the adhesive using a forward pushing motion as if you are shoveling or chiseling it off. It softens the adhesive to a point which it won't stick to your fingers and leaves no residue. There may be an oily feel and doesn't smell too great but it works pretty good actually.
After completely removing the adhesive, I go back around the bezel and clean with rubbing alcohol to remove and residual finger prints, adhesive debris, etc.
Oh and I don't recommend smoking while handling the lighter fluid and would recommend not using it around any electrical sources or batteries, etc.
Score 3
Add a comment
When it comes to removing the excess adhesive that I see when doing a repair on phones or tablets I normally have used Goof Off FG661. From my experiences it removes the adhesive extremely well.
Materials: Goof Off FG661, Bottle cap, pack of Q tips , and some paper towels just in case.
The way I proceed is poring a few of the liquid in a bottle cap or something similar as needed. Grab a Q tip and dip it into the FG661 then run the tip of the Q tip over the adhesive that you are trying to remove (Try not to over saturate so it does not run into other parts). Then with a Nylon Plastic Opening tool or something that you can scrap with go thoroughly removing all the adhesive. Continue the process through out every part that has the adhesive you are trying to remove.
This method has worked perfectly for me without any issues in adhesive removal.
Score 2
Add a comment
Goo gone and rubbing alcohol work great
Score 1
Add a comment
se a pencil eraser, I am using one I had lying around. The one that worked best is white, branded: Staedtler Mars Plastic and Made in Germany, part number 526 50. It says on its side: “Made for pencil and film” Did that after rubbing the rough goo off with a credit card. Then pencil eraser, and intermittently credit card & rubbing alcohol. Tedious but eraser is crucial. Other erasers worked but not as well as the white Staedtler.
Score 1
1 Comment:
....that's a genius idea!
by
Add a comment
I use 99% alcohol to clean the housing.
Add a comment
hi, i have an ipad mini2 my screen is broken i try to change my screen i have remove the broken screen and there is some glue still stick on it. i used the 409 and window cleaner still didn't come out. what should i use to remove it?
Add a comment
Tried 80% alcohol (windshield wiper), which had zero impact. Also tried hydrogen peroxide 3% (for cleaning wounds) just in case that works, also no impact. Acetone ultra strong nail polish remover also zero impact.
Scraping with nails seems to work best of these things, but doesn't really work. Yet to try 99% alcohol :).
Update (03/22/2017)
At the moment I used acetone and then scraped, followed by using some oil to clean it a bit more - stuff we had in the house. Still not good, but almost OK.
2 Comments:
Try goo gone its for removing residue and glues.
by
Anyone reading this, DONT use nail polish remover, it usually contains acetone which dissolves some types of plastics!
by
Add a comment
What if you are only replacing the screen, and need to salvage the OEM digitizer? Most of the adhesive peeled off, but there is still a lot of adhesive left on the digitizer. How would you get it off without scratching the color off of the digitizer?
1 Comment:
I have the same exact question as u and cant find the answer! All other answers are for the front glass screen on the phone. I cant ruin my inside lcd digitizer with scraping or the wrong liquid but i gotta get all this glue off! What did u end up doing?
by
Add a comment
morpheousman01
Add a comment
I found that paint thinner on a Q-Tip made the built up glue soft and easier to scrape off using the small flat blade screw diver that came with my new battery and touch screen, but it wasn’t safe to use on the plastic parts, only the aluminium. So, being a mechanic, I tried using several cleaners that we use in automotives. CRC CO Contact Cleaner worked just as well at softening the old tape and glue as paint thinner, but is safe on plastics. I sprayed some into a cup and used a bunch of Q-Tips, and it worked well but the contact cleaner evaporated too quickly. I then found something that works super. It is called Perfects Contact Cleaner, and it is designed to work in the Tropics where I live. While dissolving the glue, it also protects against rust and corrosion while drying colourless and with no residue. It improves electrical conductivity, cleans, and removes aluminium corrosion. Again, I sprayed some into a cup and used Q-Tips. I still had to scrape a little to remove the goo from the notch in the plastic surround, but it was easy to remove the glue, and the residue from the battery stickum came off pretty easy by spraying the cleaner on a paper towel and leaving it on the glue for about 15 minutes. Now it looks like new.
Add a comment
Ronson Lighter Fluid is the best solvent for pressure sensitive adhesives.
Totally non-destructive! I use it to remove candle wax dripped on the finest antique furniture.
Cleans mechanical watch movements.
give it time to soften adhesive then wipe with cloth or Q-Tip.
Can't recommend it enough!
Add a comment
Add your answer
Simon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 60
All Time: 27,125
