PC Not switching on
Both indicator and charging light do not turn on what could be the problem.
1 Comment:
Have you verified the power supply is working? You should see 19.5 volts coming out from the plug. If you don't have a voltmeter, you may need to try the supply with a different device or try a different charger.
by Share
Add a comment
