The Oppo A12 is a smartphone designed by Oppo and it were released in 2020.
Low sound on phone
I can't here because the Volume is low when it's on higher
Score 3
Add a comment
Turn it up and clean your speakers
Add a comment
Speaker is low sound
Add a comment
लो साउंड कलिटी
Add a comment
I can't here because the volume is low when it's on higher
1 Comment:
I know it sounds mundane, but have you cleaned out your speaker ports? It is something that easily gets overlooked, occurs frequently due to how often phones go in&out of pockets + depending on phone case design may occur more often, plus it doesn't help that depending on how the "clog" forms and/or how long it's been in the port --> even a more-than-reasonable "once over" in slightly suboptimal lighting can result in the port(s) appearing to be completely fine.
If the ports have been cleaned --> Unfortunately we're likely talking a hardware issue then (unless you're using a jailbroken / previously jailbroken device since code could be sabotaged somewhere then). Nonetheless, your best bet for a fix may be just to find a replacement micro speaker online for a couple-few bucks for your phone model, open the phone up, remove, and replace the speaker. Bonus Trick: If you do not have soldering skills and/or proper tool access, you could take it to a small shop phone repair place; it'll just cost a bit more!
by
Add a comment
Add your answer
Brend jr will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 68
All Time: 816
