How to fix monitor?
I had my laptop sent to a repair shop and they returned it fixed, so i turned it off to get dinner and when i returned, it doesn't connect to the monitor. I used an external monitor and i saw that it only scanned my external monitor and not the laptop monitor. Is this somewhat a broken connection or just a loose port? HP 15s-du2034tx
Hi @keima30928
Do you mean that nothing is shown on the laptop screen, only an external monitor, or when the external moniter is plugged in it only shows on that, not the laptop screen?
by N Kerr Share
@bananakat12345 The laptop monitor is no longer read by the device, when i check in settings on display. Only the external monitor is found
by Keima Share
Also Idk if this helps but, on rare occasions, when i boot the laptop up, the laptop monitor and the external monitor lights up showing a glitching display, like a broken tv display of rapid movements, usually pinkish in color. And after i restart the laptop, everything goes back to normal, and the laptop monitor is once again, not read/scanned by the laptop, only the external one
by Keima Share
