Up to 20% off select tools
Volume button not working
Volume button are not working while pressing it
Score 10
13 Comments
How to change volume button
by Share
@abhijitdebnath Does the existing answer not answer your question? If not, what's different about your question from the original?
by Share
Volume button repair
by Share
@abhi31782 See the Most Helpful Answer below; your issue has already been addressed.
by Share
My volume button not working
by Share
Show 8 more comments
Add a comment
Most Helpful Answer
See image content:
Score 4
2 Comments:
Kam karne Wala volume
button Kam nahin kar raha hai
by Share
Add a comment
@pranav55998 could most certainly be a bad volume button flex. To replace this and since iFixit does not yet have a guide for that, use the one from here It is written in Spanish so use a browser that does the translating for you, if needed. The volume button flex is readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Score 1
Add a comment
Well check for any sort of physical damage near the volume button area if recently your phone is drop down so that can also cause the damage on the button and also check for the latest software version update sometime an outdated software version can also cause these kind of issue as well.
Score 1
Add a comment
Add your answer
Pranav will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 79
All Time: 1,811
