A new Apple Pencil meant to be a model between the Gen 1 and Gen 2. It costs $79 USD and charges via USB-C. It has the ability to magnetically attach to your iPad, but lacks pressure sensitivity.
apple pencil tip broken
i c
accidentally broke my apple pencil tip in half and there is a piece stuck in there how can i take it off
Score 1
Add a comment
1 Answer
The tip is screwed in (at least in the one I have). As it's a soft material Vs its fitting you should be able to use a left wound drill bit to grab the remaining tip to unscrew it out. Just like a screw you want the turning of the drill to turn in the direction to come out.
A left hand drill bit held in a jewelers vise is what you need and a bit that's smaller in diameter of the fitting to slowly ease it out.
Add a comment
Add your answer
Luis Diaz will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 66
All Time: 534
