The Xiaomi Poco M2 Pro is a mid-range smartphone by Xiaomi released July 2020. It has a 6.67" IPS LCD display, a 48 MP main camera, a 5000 mAh battery, a side-mounted Fingerprint, and runs on a Snapdragon 720G.
Back pannel is coming out
The back pannel of my phone is coming out automatically
Score 1
3 Comments
Back panal not opinig
=== Update (09/10/25) ===
Back panal not remove
Poco m2 pro Repair information for the
by
Black panal not oping
by
Yes my phone back pannel out now and broken
by
Add a comment
Most Helpful Answer
@harshitshu72093 could be a bad back cover, not enough adhesive. It could also be caused by a battery that is expanding, which would be bad. For now stop using your phone and remove the back cover to look at the battery. If it is puffed up, then you must replace it. Otherwise it can easily "vent with flame" which means it could come on fire. If unsure, remove the back cover and take a picture of what you see. Then post that with your Question.
If it "just" the cover, use some adhesive like E-6000 to keep it is place, or replace the caver if it is damaged.
Adding images to an existing question
Score 1
Add a comment
Mera dost ka byan pahle back panel ka kharab Hui Hai uska toss ke nahin rahata Hai nikal jata Hai Kaisa kya kaise kya karun
Add a comment
Add your answer
Harshit Shukla will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 26
All Time: 295
