The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
Turn signal stops blinking.
When I turn on my turn signal, sometimes it doesn't blink at all. Other times it blinks a few times and stops. The control lever was broken when I got the vehicle and I thought that was the cause but replacing the lever did not fix the blink issue.
Add a comment
1 Answer
Here are the next troubleshooting steps I recommend
  • Replacing the flasher relay is cheap, easy, and likely the solution to your problem VIDEO GUIDE
  • Checking the signal lamp Frame grounding point
    • There should be a wire that attaches straight to the frame from the headlight assembly. Remove it and sand underneath to remove any rust or corrosion, and replace it.
    • Here are the signal lamps' electrical schematics
These are the easy things to check. If this doesn't get you there, I'd recommend consulting a professional auto mechanic.
Add a comment
Add your answer
Dan S. will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 5
All Time: 139
