24 inch, 165hz, qhd pc monitor
In display water is entered
In my dell display some drops of water enter how to remove water
1 Comment:
@anupkumaryadav where did the water enter and what is the outcome? What does your screen show you now? Post some pictures of what this all looks like. Adding images to an existing question Some of the displays can be disassembled and cleaned but we will need to see more of this
by
Add a comment
1 Answer
Water damage to LCD panels is unfortunately irreversible if the image is black in places and shows bright lines or patchy/distorted colors; your only option is to replace the display.
You can try blow-drying the monitor on low heat with a hair dryer, but if the water damage is anything but the most minor severity, this is an unlikely fix.
Add a comment
Add your answer
ANUP KUMAR YADAV will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 20
All Time: 312
