How to replace the fans
Im trying to just replace one of fans that's vibrating and very loud. Im unsure if I can actually replace just one fan without replacing the whole cooling solution
Add a comment
1 Answer
Most Helpful Answer
Hi @copycap
Here's the hardware maintenance manual for the laptop.
Go to p.32 (38 of 66 pdf) to view the procedure to remove the Thermal module.
Looking at the parts list for the laptop (see image below) it seems as though you may not be able to replace just one fan as the replacement part comes as a complete module.
You could always check if there's any information printed on the fan itself, to see if searching online using the information gets results for just the one fan. Worth a try anyway.
If you decide to replace the module, search online using the part number only to find suppliers that suit you best.
(click on image)
Score 1
Add a comment
Add your answer
CopyCap will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 536
