Repair Guides
Learn how to fix just about anything with our step-by-step guides.
App
Your pocket repair helper.
FixBot
The friendly AI repair assistant.
Repairability
Learn why fixable products make sense.
Teardowns
Get a sneak peek inside the latest gadgets.
Answers Forum
Share solutions and get help from a friend.
Find Your Community
Find teams, events, and fellow fixers.
Help Out
Help make repair knowledge free and accessible for everyone.
Right to Repair
Learn about the Right to Repair movement and how to be an advocate.
Featured
Quality parts and tools backed by our lifetime guarantee.
Tools
Shop our wide selection of precision tools.
Parts
Shop parts backed by our quality guarantee.
iPhone Batteries
Batteries tested and guaranteed plus a kit with everything you need.
A 32-inch 1080p LED TV manufactured by Sony under its Bravia family.
bablu shaik @bablushaik
Rep: 1
Posted: Jul 18, 2025
Power button on of problem
4 Comments:
Past 30 days
Jul 18, 2025 by bablu shaik
==== 1. Check the Remote Control First ====
* Make sure the TV responds to the remote’s power button.
* If the remote works fine, the problem is likely with the physical button on the TV.
==== 2. Inspect the Power Button Physically ====
* The button might be stuck or dirty.
* Gently press it multiple times to see if it loosens.
* Use a can of compressed air around the button to clear dust or debris.
==== 3. Unplug and Power Cycle ====
* Disconnect the TV from the power outlet.
* Wait for about 5 minutes.
* Plug it back in and try the power button again.
==== 4. Try the TV’s Other Buttons ====
* If your TV has other buttons (volume, channel), check if they respond.
* If all buttons are unresponsive, the issue might be with the control board.
==== 5. Inspect the Internal Button Connection (Advanced) ====
* If you’re comfortable opening the TV:
** Unplug the TV.
** Remove the back panel carefully.
** Locate the power button assembly on the mainboard.
** Check if the button or ribbon cable is damaged or loose.
** Clean the button contacts with isopropyl alcohol.
* Only do this if you have experience with electronics and the TV is out of warranty.
==== 6. Use the Remote or External Device ====
* Use the remote control or connect a device like a universal remote or smartphone app (if supported) to turn on/off the TV as a workaround.
==== 7. If Button is Faulty ====
* The power button assembly or control board might need replacement.
* Contact Sony support or a certified repair center for parts and service.
Jul 19, 2025 by Asha Kanta Sharma
@i_am_the_cosmos AI Generated Technobabble
Jul 22, 2025 by oldturkey03
@bablushaik what exactly is it that your TV does or does not do? Does your Power LED still light up? Does it blink? Can you verify that your TV is a Sony KDL-32W670A? We need more details.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 159
Past 30 days
by bablu shaik
** Unplug the TV.
by oldturkey03
by oldturkey03
