Up to 20% off select tools
The first FWD car to be exported to North America by Volvo
Radiator Fan not working.
How can i test my Volvo Radiator Fan 1994 volvo estate 850 T5 radiator fan to make sure it is working correctly.
Score 2
Add a comment
1 Answer
Chosen Solution
mike, you can disconnect the fan motor plug from the relay, and supply power and ground to the fan motor directly. If the fan runs, you probably have problems with the relay or the temperature sensor. The temp sensor is just below the thermostat in the lower thermostat housing near the power steering pump. The attached diagram show you the wiring for our Volvo> Hope this helps, good luck.
Score 2
3 Comments:
Thank you so much oldturkey 03, the radiator fan is now working
by Share
Thank you so much oldturkey 03, the radiator fan is now working,you are magnificent.
by Share
Thank you for accepting my answer and you are welcome :-)
by Share
Add a comment
Add your answer
mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 38
All Time: 8,671
