Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
iPhone 8 not recognizing Charge. Suggestions?
Hi I am hoping this gets some attention before I send my phone away, im pretty sure i know whats broken but just want to check to see if there's anything else I could check first.
I was working on my iPhone 8 as it needed a new Battery as I was working on it I accidently broke the ribbon connector for the Taptic Engine, I finished installing the battery while i waited for a replacement engine and the phone worked fine. However While i was Taking it apart to replace the Taptic i forget to disconnect the battery in my haste and now the phone will not show battery Percentage or seemingly charge, it will eventually show a percentage after sitting on a wireless charger for a while but in that time it randomly turns on and off. all i have found googling is that I must have damaged the MOSFET's, they dont look damaged but they could be.
Sorry for the long Question hopefully it makes sense.
Does anyone else have suggestions on what else it could be before i send it away?
Score 1
1 Comment:
Add a comment
1 Answer
I'd recommend changing out the entire charging port flex cable.
You can find the part with or without the exact toolkit you need
HERE
iPhone 8 Charging Port flex cable Replacement
Replace a lightning connector assembly compatible with the iPhone 8. Includes the flex cable, logic board connector, lightning connector socket, and two microphones. Part #821-01163. Image
Product
iPhone 8 Lightning Connector Assembly
$49.99
Add a comment
Add your answer
que que will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 196
