The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Difficulty finding the cubic foot
Cubic foot? model number 110.28102310 wife says its a double loader
Add a comment
1 Answer
Most Helpful Answer
Hi @hotknife
Most Kenmore 110 series washers have a cubic capacity of 3.2 cu.ft.
The owner manual doesn't specify the capacity of the washer, only the soil level types but you can work it out using the formula used to find the volume (capacity) of a cylinder i.e. the tub (drum) is a cylinder
  • V= Pi (3.14) x r² x H (V= 3.14 x r x r x H)
V= Volume (capacity), r = radius of tub i.e. measure the diameter of the tub and then halve it and H = height of tub i.e. measure the height of the tub from the bottom to the top of the tub.
If using inches as the measure then ensure to make the radius and height values measurement relate to feet e.g. 16" = 1.33', 27" = 2.25' etc to get the answer in cu.ft
Score 1
Add a comment
Add your answer
hotknife will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 41
All Time: 788
