Repair your UH70800 WindTunnel 2 High Capacity Bagless Upright Hoover vacuum with a replacement part guide.
Vacuum has no suction power!
How do I check the suction hose on vacuum?
Add a comment
1 Answer
Most Helpful Answer
Hi Beverly,
I would start by checking if the hose is blocked. Try to unplug the hose from the main body of the vacuum cleaner and see if the suction is better directly on the hose plug hole.
Then, I would check and clean the filters of the vacuum.
good luck
Score 1
Add a comment
Add your answer
Beverly G Palms will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 208
