Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Trackpad not physically clicking after cleaning
Hi all, ever since I bought my Early 2011 15-inch MacBook Pro, I hated that the trackpad seems to stick out ever so slightly at the top, while the bottom of the trackpad is slightly recessed into the casing. It's only half a millimeter at the top and one millimeter at the bottom, but it's still noticeable. So I thought: why not take it apart to see if I can do something about it.
Everything went very well, until I tried to reseat the trackpad into the case. I used four stickies to properly align the trackpad. But after multiple hours of trying different combinations of the bottom and top screws, I was never able to make it 'click' like it did when I took it apart. Now, I have to use quite a lot of pressure on the bottom center of the trackpad to trigger a mouse click. It doesn't make a mechanical 'click' sound anymore. While it did so perfectly before I took it apart.
I already checked the button at the bottom of the trackpad itself, and that seems to click down just fine.
I also couldn't resolve the issue of the trackpad not fitting in properly, every time I screw it in place, it will always stick out at the top of the case. I only wiped the trackpad down and I made a small mistake while following the guide: I accidentally loosened up the black screws at the top of the trackpad hinge. I screwed them back down.
TL;DR: After taking a good, working trackpad out of the Mac, it only registers a mouse click in software when I firmly press on the lower middle of the trackpad. It doesn't make a mechanical 'click' sound anymore. Even after hours of fiddling with the alignment and all top and bottom screws.
EDIT 06-29-25 23:12
Because some things are hard to explain, I hope that this image makes the problem clearer.
EDIT 06-30-25 00:43
Well, I took the whole thing apart again. For my own sanity, I removed everything that had to do with the trackpad to 'figure out' what each part did. First I removed the small silver tabs at the top of the trackpad. I inspected them against some images of new ones I found online. They look nearly identical. I also removed the trackpad itself to see if it maybe was bent. And while there is an ever so slight curve in the center (about 0.005 mm difference with the edges of the trackpad).
I also removed the big shiny screw that's supposed to handle the button in the bottom center of the trackpad, and inspected the button itself. Both look fine to my eyes. I also tried pressing it with a screwdriver, and it clicked like it was new.
Then, I tried to line up the trackpad as good as I could. None of the edges have any friction. But when I tightened the silver screws at the top, this happend.
So, I loosened the silver screws, positioned the display at 90 degrees, and laid the bottom case on my desk. While applying a lot of pressure, I tightened the silver screws again, but, because of the pressure, the trackpad couldn't go up much at all. After doing that, the trackpad is still 0.05 mm higher than the frame, but it's much less than it was before.
Next, it was time for the set-screw (big silver screw at the bottom center). Long story short, I can't get it to click normally. Right now, I have it set where the trackpad has just enough freedom to move and make a (really soft) 'click' sound, but I have to apply quite a lot of pressure to let that 'click' register in software. It doesn't matter how slow I turn it, it never goes back to that loud 'click' sound every MacBook user if familiar with.
This is the full trackpad assembled in the bottom case (without set-screw):
EDIT 06-30-2025 14:59
Well, I took the Mac apart one again to check the button at the bottom of the trackpad (the small silver nub). I tested it while the Mac was booted into OS X. The button works like a charm. I have to put very little pressure on it, and you hear a loud 'click' that you suspect from these MacBook trackpads. The mouse click in software activated immediately once you hear the 'click' sound, as it supposed to be.
Next, I completely removed the silver screw at the bottom of the trackpad (the adjustment screw) and tested the trackpad, while the Mac was still booted into OS X. I tried the trackpad again with every 5 degrees I turned the screw inwards. I always have to apply quite a lot of pressure on the glass surface to activate the software click, but I never hear the button 'click'. The trackpad itself doesn't make a 'click' sound at all, apart from a very muffled sound which does not correspond to the button being pressed, since it doesn't register the 'click' in software.
NOTE: The bottom case was not screwed in when I took the pictures, that's why it may look strange from the sides.
Next, I checked the chassis of the Mac, as suggested by @danj. As far as I can tell, the frame is completely straight. The ruler doesn't have any wobble.
Add a comment
OK, you've got two issues here, let's start on the top edge problem first, here we need to add thickness between the case and the trackpad clip to reduce its height. If we look at Step 27 in this guide MacBook Pro 15" Unibody Early 2011 Trackpad Replacement the Red Circled screws is what you should have removed (Silver). Here we need to remove the black inner screws so we can shim under them. There is very little adjustment here as the hollow within the trackpad where this tab fits into is limited. If you swapped the screws around the screw shaft can also cause the tab not to correctly sit. So after removing the trackpad make sure the shorter black screws are here. As for what to use I would use a piece of thick paper cut to fit the tab under the spring that runs across to the screws that hold the trackpad.
Now with the trackpad correctly placed you may need to adjust the click. Now jump to the trackpad part here MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad look at the backside image note the middle top edge silver button that's a blister button the middle set-screw hits to enable the click and it also gives you hepatic feedback.
So carefully holding the system upside down the trackpad should dangle a little If not the set-screw is to far out, back it off a half turn and see if that did it. Be careful! As you can go to far.
Replace a trackpad compatible with the Mid 2009 to Mid 2012 model A1286 MacBook Pro 15 inch Unibody laptop. Part #922-9035, 922-9306, 922-9749. Image
Product
$43.99
18 Comments:
Thank you so much for your reply. I've added a picture which hopefully adds some context. I removed the small black screws at the top of the trackpad first, by mistake. After I realized my mistake, I put them back in and removed the small silver screws. The small silver parts, with the slightly bent ends are the springs, right?
by
@alwinlubbe93691 - Yes, the spring goes across the tab (held by the black screws).
Do be aware the trackpad is at a slight lower position than the case about .25mm you had expressed the issue was the trackpad was above the uppercases edge. The image you posted looks correct! Maybe you only need to adjust the click action.
by
@danj Thank you so much for your clarification. After taking it apart, I still have the same issue. I've put more details in the original post. Again, thank you so much for your time!
by
@alwinlubbe93691 - Well now it's clear the set-screw is missing!
So there is no means for the trackpads blister switch to be pressed. If you look you can see the blister switch in your image. Now look at the guides image you can see there's something in the hole!
Here's the needed part Unibody MacBook Pro 13" Trackpad Adjustment Screw
by
@danj Hi dan, the adjustment screw is there. You can see the underside of it in the second photo in my original post.
by
Show 13 more comments
Add a comment
Well I will suggest you to Use External Mouse Temporarily until the issue not get fixed.
1 Comment:
I'm currently using my MX Master 2S for the time being. I don't want to shatter the glass due to force.
by
Add a comment
Add your answer
Alwin Lubbers will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 33
All Time: 498
