Resetting the reset indicators
Refrigerator: Frigidaire model GRSS2652AF
Age: Just past the warranty period
Both the ‘Reset water filter’ and ‘Reset air filter’ indicators are on. The manual clearly states “15: Air Filter The display shows the current status of the air filter (Good, Order, or Replace). To reset the filter status to Good, press and hold Air Filter for 3 seconds.” I have done this, but the indicator is still lit. Exact same thing for the water filter.
What else can I try?
2 Comments
Replace filter,makes ice no water
by Arthur Franklin Share
@arthurfranklin
Try pushing the filter in a fraction more so that you hear it click.
If it won't go in any further, turn off the water and remove the new filter and reinsert the old filter (until you hear it click into place) and check if you get water.
Sometimes replacement filters if they're not OEM are not exactly the correct specifications regarding the tabs so it doesn't quite fit correctly to open the valves in the filter housing when it's inserted.
by jayeff Share
