How do I wire up the vsr trigger switch
I have a new switch I need to install on the drill bit don't know how to wire it
A
A
I don't know if wiring diagrams are available for your drill, but generally my process is to open the drill up to get to the switch, then use the existing switch as a guide to where each wire goes. Take one wire at a time and move it from the original switch to the corresponding point on the replacement part. Is there a reason that won't work for you?
To much time between new switch arriving. Took old switch out to get part number and. Don’t remember sequence to put back
@tony20811 How many wires go to the switch?
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 197
