Support and repair guides for the Lenovo ThinkPad T480. Released in January 2018.
Not charging and not turning on
My laptop is not showing any charging indication and also not power on and I tried with removing battery and charging but it fails to power on
1 Comment:
Charger is working correctly
=== Update (06/17/26) ===
Yes not turning on and also not showing any charging signal
by
Add a comment
1 Answer
Have you verified that your AC adapter is putting out power? A USB power meter would be best, but at the least you should try it with another device or try a different adapter if possible. That way you can eliminate the charger as the problem instead of the laptop.
Add a comment
Add your answer
Abhi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 28
All Time: 414
