Repair guides and support for the Willys-Overland CJ-3A "Civilian Jeep," manufactured from 1949-1953.
Why wont my jeep start
points and condenser have been replaced the coil too but when turning over there iis no fire power to the coil
Score -1
Add a comment
1 Answer
Chosen Solution
Susan Luntsford, you did not tell us if it is stock or if it is a mod jeep. Engine Size and mods are important since it does make a difference. If you have no power to the coil, check your ignition switch. Make sure the switch close the circuit to the ignition coil. Check the wiring from the positive terminal of the battery to the switch, make sure it is connected and not shortened out. If it worked before, but stopped working since you replaced the parts, double check your work.
Score 5
Add a comment
Add your answer
Susan Luntsford will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 33
All Time: 3,626
