A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Headless mac stuck on apple logo screen
My late 2017 MacBook Pro screen went black. I assumed the MacBook was coming on since the caps lock light would light up. I tried various reset keys and nothing worked. Local apple repair said screen went out. Went down the headless mac rabbit hole and determined this could work for me with an external monitor. Took the Mac screen off and connected to external screen. I’m assuming mac is coming on as the external screen shows an apple (without a loading bar) and the caps lock light still comes on. I’ve tried various reset keys again and nothing is working. I’ve also tried the command f1 to allow screen mirroring and that didn’t work either. What should I do next? At the very least, I need to access the data and get it backed up or onto another device. How is the best way of going about that or have I already lost the data? Can I still fix the Mac and use it headless? Help!
Add a comment
1 Answer
Most Helpful Answer
Your stuck! The lid its self has a function in altering the video output from the internal to the external.
As it's not shut (clam shell mode) the external won't become the primary display. So how is this done is the clue and the answer!
The logic board has a Hall sensor which senses the magnetic flux from a magnet which is embedded into the lid. Here's the location on the logic board
Now this is the backside of the logic board pressed into the palm rest just above the ports. So getting a rare earth magnet and placing it over this location will switch the video output to the external as the primary display. Hopefully that fixes your issue.
Score 1
Add a comment
Add your answer
April Weiss will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 40
All Time: 611
