Up to 20% off select tools
The Black+Decker LM175 is an 18-inch 6.5-amp corded electric push lawn mower with a one-touch height adjustment, a polymer mowing deck, and a folding adjustable handle, designed for residential use. Model numbers include LM175 and 12411047.
How to charge it?
How to charge it and what cord do I need to use
Add a comment
1 Answer
Most Helpful Answer
Are you sure you categorized your question under the correct lawn mower model? Because the one you've got is a corded lawnmower, meaning it must be plugged in to run at all; it can't be charged because it doesn't have a battery. The cord you need for this mower is a standard heavy duty outdoor extension cord. How long it needs to be depends on how big your yard is.
Score 1
Add a comment
Add your answer
Patience Eichelberger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 218
