Up to 20% off select tools
An HP desktop computer released in 2008.
Window 7 sound not working problem
Update (05/22/25)
Window 7 sound not working problem solution
Add a comment
1 Answer
  • Check Audio Settings
    • Right-click the speaker icon in the taskbar and select Playback Devices.
    • Ensure the correct audio device is set as default.
  • Update or Reinstall Audio Drivers
    1. Open Device Manager and locate Sound, Video, and Game Controllers.
    2. Right-click the audio driver and select Update driver.
  • If updating doesn’t work, uninstall the driver, restart the PC, and let Windows reinstall it
  • Check Physical Connections
  • If using external speakers or headphones, test with another device or port to rule out hardware failure.
  • Download Drivers from HP Support
    • Visit HP Support and search for HP a6500f to find compatible audio drivers for Windows 7.
    • Install the driver, restart your PC, and test the sound output.
  • If none of these steps resolve the issue, consider testing with a Linux Live USB to determine if it's a hardware or software problem. Hope this helps!
Add a comment
Add your answer
Dipanshu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 247
