Repair guides, disassembly, and troubleshooting information for the 5th-generation Apple iPad, available in Wi-Fi and cellular versions with 32 or 128 GB of storage. Released in March 2017. Identified by model numbers A1822 or A1823. Features a 9.7" Retina display and 64-bit A9 processor.
My iPad 5 not changing
Add a comment
1 Answer
Most Helpful Answer
To troubleshoot a device not charging, you can first try using a different charger to check if the charger is at fault. You can also try using a different wall outlet to make sure it isn't the wall outlet that's at fault. You should also inspect the charger and charging port for any visible signs of damage or debris blocking the charging port.
Score 1
Add a comment
Add your answer
Cchaya84@gmail.com will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 166
