Announced on October 13th, 2020, the iPhone 12 mini is a smaller version of Apple's iPhone 12. It features a 5.4-inch OLED display, an A14 Bionic processor, and dual rear cameras.
Little metal pin broken off
Hi everyone.
I found out today that a small metal pin on the bottom of my iphone broke off. It doesn't seem to affect the phone at all, but can someone explain to me what it's for?
I can see that it was supposed to touch a dot on the back of the screen.
I have marked the small metal pin in yellow at the bottom of the phone.
I hope you can help me answer this question, thanks
Add a comment
1 Answer
Chosen Solution
That is a chassis grounding strap which via its spring action connects to the back of the display assemblies back panel offing both a static and EMI pathway to the main case. As long as the second tab is not damaged I think you'll be OK. Otherwise you'll need to replace the speaker unit.
Score 2
4 Comments:
Thank you very very much!
The other strap is fine.
Again thank you for your answer
by
@rasmushenn39758 - If you're set, don't forget to accept the Answer. Thanks!
by
does this affect charging? because after i put my iphone back together my charging has been weird. Anytime I connect the charger, it shows the message that it shows when you just connect something.
"16% charged" then dissapears as normal.
But when i come back to the phone the charging icon isn't even there and my phone is still on the same battery level I left it on
by
@daveu - EMI shouldn't effect charging, a static discharge could damage some sensitive components. You likely have a deeper issue that needs looking into.
by
Add a comment
Add your answer
Rasmus Henningsen will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 58
All Time: 325
