Up to 20% off select tools
What's inside a chip? How does it work? Computer chips are also called integrated circuits, monolithic integrated circuits, ICs, chips, or microchips.
Help Identifying a chip
Hello, I have a Vizio S2920w Soundbar which has a blown chip on it. I was wondering if anyone here could help identify it. Its marked 9F 2 and has U7 written on the board beside it. All help would be appreciated!
Score 1
3 Comments:
Hi, I’m having the same problem. Were you able to identify the component? That would be a great help.
by Share
@albert45304 from whatever is left to identify the component, this could very well be a Voltage regulator. Check on here You can relatively easy identify if it is a V Reg if one of the middle pins looks a bit odd. Again datasheet will show what I mean by that. You can also desolder the component and check the bottom side for what the center pins look like.
by Share
@oldturkey03 Thanks, that was really helpful. It’s definitely one of these.
by Share
Add a comment
1 Answer
It looks like you have some other material to remove and underneath that there are the actual identifying markings.
1 Comment:
Unfortunately I cannot remove that as thats the actual plastic itself which has burnt and turned white.
by Share
Add a comment
Add your answer
TechVid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 263
