Poco M4 Pro 4G Released 2022, March 16 179.5g, 8.1mm thickness Android 11, MIUI 13 for POCO 64GB/128GB/256GB storage, microSDXC
Charging problem to my phone
When I put my phone on charge it is not getting charge faster and having automatically charging on and off problem why it is happening?
Score 2
Add a comment
Hey there!
If I had to assume, I would say that your charging port has a bad connection to its PCB. Before you open it up to look, however, make sure you try a different cord and/or a different wall outlet to make sure they aren't the problem. I would also check your settings to see if you have "prioritized charging" or something along those lines turned on. The setting could be making your phone not charge at certain points.
If you have confirmed that everything I've listed isn't what's wrong, I would either open it to see if the charging port is bad, or even take it to a local repair shop to have it looked at.
Best of luck!
Add a comment
Poco m4 pro 4g speaker was filled by dust
Add a comment
When I put phone on charging charging was soo slow
Add a comment
Mere pass do data cable hai me dono se charge kata hu ek data cable se perfect charge hota hai dusri se battery kam hoti rehti hai charging PE lagane ke baad
Add a comment
Add your answer
Bm amer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 679
