Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
How can I make it turn on?
It seems a battery exploded inside the port and calcified the connector and it's surroundings. I already cleaned it as best I could with a bit of alcohol but it doesn't seem to register that it has batteries, even though I put in fresh ones. That being said, when I connected it to my laptop through cable it seemed to receive power and turn on.
Add a comment
1 Answer
Hi Alex!
Oh my... The only thing you can do is to clean it with isopropryl alcohol. The whole motherboard, but this is what you already did.
So, the next step is to replace the battery pins for new ones! Soldering is required, but it's not that difficult.
If that didn't worked, then there is something (or more things..) damaged on the motherboard. If this is the case, it's probably not worth to repair it. Sorry.
Hopefully replacing the battery pins will do it!
Add a comment
Add your answer
Alex Gonzalez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 154
