Echo SRM-225 Trimmer. This model replaced the SRM-210. The most common repairs for this device are straight forward and can be done quickly.
String line not cutting-cutting off
the string line is not cutting off. When i push the head down, more string is let out, but the excess line is tangling around the feedhead, and not cutting off when the line comes across the blade
Add a comment
1 Answer
There should be a small blade on the underside of the debris shield that cuts the string when it is let out. Is this blade missing? broken? clogged? dull?
If missing, search Echo part # Echo 69901644330
Add a comment
Add your answer
Mike Harrison will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 222
