Repair and disassembly guides for the Nintendo Switch OLED Model, announced and released in 2021.
Got wet, what next?
Found under my children's bed unresponsive and dry, kids claim it got wet. What do I do next?
Add a comment
1 Answer
Hi @coridaw
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the game console's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on the device and then remove the battery as soon as possible to minimize any further damage.
Then you need to dis-assemble the rest of the device and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this it might possibly work correctly again.
Here is the ifixit Nintendo Switch OLED repair guide that may help
If this process seems too daunting, take the console to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Add a comment
Add your answer
Cori Daw will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 35
All Time: 338
