Water in my phone
بعد از این که گوشیم داخل آب افتاد دیگه آنتنش کار نمیکن
Translation Persian - English
After my phone fell into the water, its antenna no longer works.
@alihamehvand you are not telling us what you have done about the water damage. For now you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using something like this video Take a close look at all components and connectors. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields from the main board. If you do not remove the shields, you are not cleaning the board.
After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide. Even so it was written for an Apple 3G iPhone, all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. With a water immersion like yours I also replace the daughter board (charging board) since that will give you a known-well starting point should further troubleshooting become necessary. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help.
Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Translation
@alihamehvand شما به ما نمی گویید که در مورد خسارت آب چه کرده اید. در حال حاضر میخواهید دیگر تلاش برای شارژ، همگامسازی یا استفاده از تلفن خود را متوقف کنید. این به طور بالقوه می تواند وضعیت بد را بدتر کند. این ممکن است به گوشی شما آسیب بیشتری وارد کند.
کار بعدی تمیز کردن آن است. گوشی خود را با استفاده از چیزی شبیه به این ویدیو جدا کنید به همه اجزا و کانکتورها نگاهی دقیق بیندازید. به دنبال خوردگی عمده باشید، پین ها را در کانکتورها و غیره ارزیابی کنید. به تمام کانکتورها و همچنین انتهای کابل نگاهی بیندازید. شما باید تمام سپرهای EMI را از برد اصلی حذف کنید. اگر سپرها را جدا نکنید، تخته را تمیز نمی کنید.
بعد از اینکه آنها را جدا کردید، کل برد، کانکتورها و همه آنها را با +90٪ ایزوپروپیل الکل تمیز کنید. [راهنما|5825|این راهنما] را دنبال کنید. با وجود این که برای آیفون 3G اپل نوشته شده بود، همه نکات همچنان به گوشی شما مربوط می شود. در حالی که برد خود را تمیز می کنید، آسیب های آشکاری مانند سوختگی یا گم شدن قطعات و غیره را بررسی کنید. وقتی برد به درستی تمیز شد، باتری را تعویض کنید. با غوطهوری در آب مانند شما، برد دختر (برد شارژ) را نیز تعویض میکنم زیرا در صورت نیاز به عیبیابی بیشتر، نقطه شروع خوبی به شما میدهد. تمام این مراحل برای جلوگیری از شکست تاخیری ناشی از خوردگی است. بهترین کار این است که آن را با یک پاک کننده اولتراسونیک تمیز کنید، اما اگر به یکی از آنها دسترسی ندارید، این حداقل کمک می کند.
پس از انجام همه این کارها، گوشی خود را دوباره جمع کنید و دوباره ارزیابی کنید. تا زمانی که تمیز نشود، همه چیز فقط یک حدس خواهد بود. حتی با وجود همه اینها، آسیب های ناشی از آب فقط شانس کمی برای ترمیم کامل دارد، اما حداقل می توانید آن را امتحان کنید.
مرسی از راهنماییت
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 117
