Xiaomi Redmi 10 has a 6.5 in (165,1 mm) IPS LCD display with 1080p+ (2400x1080) resolution (395 ppi with 20:9 aspect ratio), 16M colors, 90 Hz refresh rate .
Why my phone open apps by itself?
Why my phone open apps and clicking on the screen without touching it?
Add a comment
1 Answer
@yasinebrs sounds like you maybe experiencing something called "Ghost Touch". That originates from a failure between the digitizer and the rest of the screen. You will have to replace the screen assembly. Since iFixit does not yet have a specific guide for this, use the one from here It was written in Spanish so use a browser that does the translating for you (if needed). Replacement screens are readily available and not to expensive. Just do an online search and select a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this. Repair is War on Entropy!
Add a comment
Add your answer
Yasine Brs will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 23
All Time: 112
