Up to 20% off select tools
The larger version of Samsung's flagship phone, the Galaxy S8+. Released in April 2017.
SIM card door locked
I can't open the SIM holder, it seems to be stuck; how can I remove it to take out the SIM?
I tried using a paper clip, but it doesn't click because it seems stuck.
Add a comment
1 Answer
Chosen Solution
This one can be tricky because you dont want to force anything causing damage. Do you have access to a proper sim eject tool? I know a paper clip should and will work, however, I have had this very issue you are explaining. Worst case scenario is that you will need to remove the back and reset the sim eject pin. It's a black plastic pin near the sim tray that looks like a tiny cylinder.
Score 1
Add a comment
Add your answer
Piero Sabino will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 26
All Time: 263
