The Acer Aspire R7-371T-72CF is a convertible touchscreen laptop released in April of 2015. The model number for this product is: R7-371T-72CF.
Why no power on laptop?
Betty charging problem
Add a comment
1 Answer
@shahzaibramay first you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the connectors are not bend etc. Check the DC-in jack on your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged.
Add a comment
Add your answer
Shahzaib Ramay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 129
