My laptop is very slow
My laptop takes long time to boot
Add a comment
1 Answer
Most Helpful Answer
Hi @nawanephap97466
If Win10 or Win11 is installed in the laptop, try the following and check if it resolves the problem.
Turn on the laptop and when it boots into Windows, press and hold the laptop's power button operated until the laptop shuts down.
Do this 3 times in a row i.e. start > boot > force shutdown > start> boot > force shutdown > start > boot etc.
On the 3rd attempt it should boot into the Windows Recovery Environment menus.
If it does go to Troubleshooting > Advanced > Startup repair and follow the prompts.
Be careful if you decide to select Reset this PC in the menus, because if you select the wrong option next, you could erase all your personal data as Windows will be reinstalled on the laptop.
Score 1
Add a comment
Add your answer
Nawane “phapha Kev” Kevin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 154
