Up to 20% off select tools
Boot device not found
Not opening, shows that os not found .Install an os on your hard disc 3FO
Add a comment
1 Answer
Most Helpful Answer
First go into the BIOS run the HP diagnostics on the drive.
HP Diagnostics
What is the result?
Check that the hard drive is securly connected inside the laptop.
If it is and you still get that message the drive may have died.
Score 2
Add a comment
Add your answer
Vikrant Pathak will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 232
