Slim, lightweight and stylish, the Swift 3 is the ideal laptop for working on the move. The latest NVIDIA® GPU, Intel® CPU and long battery life are housed inside a choice of displays: an elegantly silver chassis with a 13.5” 3:2 ratio 2256x1504 IPS VertiView Display or the vivid colors of a 14” 16:9 FHD IPS display.
My fan is being loud
sometimes when i tilt the computer or kind of bump into it the fan starts to make very loud noises
Add a comment
1 Answer
It looks like your fan might be loose, misaligned, or have debris inside. Here are a few things you can check:
  1. Loose Fan or Screws – Open the laptop and check if the fan is securely mounted. Tighten any loose screws.
  2. Debris or Dust – Dust buildup can cause imbalance. Clean the fan using compressed air or a soft brush.
  3. Bearing Wear – If the fan's bearings are worn out, it may need replacement.
  4. Cable Obstruction – Check if any internal cables are brushing against the fan when you move the laptop.
  5. Physical Damage – If the fan blades are cracked or bent, replacing the fan is the best option.
If the problem persists, consider replacing the fan to prevent further damage to your system.
Add a comment
Add your answer
Matěj will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 193
