Up to 20% off select tools
The Nokia 5130 XpressMusic is one of Nokia's mobile phones in the series of XpressMusic. It was released in January 2009 and discontinued in 2011.
remove the memory card password
I forget memory card password please help me
Score 18
Add a comment
Most Helpful Answer
Sreenu, try this "
Go to file manager on your phone
Go to settings and choose system folders,
In the System folder, find a file called mmcstore
Send the file to your PC using IR/Bluetooth
Open the file in Notepad
The password you need for your memory card is located within that file"
The other thing that might work for you is to "
1. Insert your card into your phone, without accessing it through the phone
2. Run FExplorer and Open the path C:\system
3. Find the file called mmcstore, and rename it mmcstore.txt
4. Copy that file (mmcstore.txt) to your PC and open it in Notepad
5. Your password will be located within that file. From here
One more thing you could try is to use a memory card read for your computer and format the cared through that. Hope this helps, good luck.
Score 4
1 Comment:
there is nothing with the name of File manager or application manager in Nokia 5130
by Share
Add a comment
Score 3
Add a comment
i forgot my memory card password please help me remove
Score 3
Add a comment
yes
Score 3
Add a comment
nokia c5130 memory card not opned
Score 1
Add a comment
how remove the forget passowrd
Update
how to remove the forget password of memory card
Update
tell me hoe remove password
Score 1
Add a comment
how remove the password of memory cad forget
Score 1
Add a comment
i forgot my memoey card password please help me remove
Score 1
Add a comment
to know the password
Score 1
Add a comment
hellp
Score 1
Add a comment
i didnt know about system folder in my phone
Score 1
Add a comment
Forget memory card password
Score 1
Add a comment
how to unlock my password
Score 1
Add a comment
Hello., i've tried this for my Vivaz U5i sony ericsson. use thirdparty file managers like Xplore or others that has an option to show you hidden files. then follow the steps of @oldturkey03 . never update Xplore because i can't see again mmcstore file after update. now i got 2 mmory cards cannot be used bcoz of password. my Vivaz has now a broken resistive touch. but anyways goodluck guys :)
Add a comment
Yes I forget my memory password
Add a comment
memory card password unlock
Update (09/12/2017)
my memory card password unlock
Add a comment
Remove tha memory card password
Add a comment
Add your answer
Sreenu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 33
All Time: 32,439
