The Honda Fit, also marketed as the Honda Jazz, is a five-door, front-engine, front-wheel drive B-segment subcompact car manufactured and marketed by Honda since 2001 and now in its third generation. Marketed worldwide and manufactured at ten plants in eight countries, sales reached almost 5 million by mid-2013.
Why my car is over heating
Why water don't flow
Add a comment
1 Answer
What year is the Fit?
Most common causes of overheating are a failed thermostat or water pump. Thermostats are significantly easier to replace than a water pump so if you’re going to do it yourself that’s where I’d start. If that doesn’t help, I would take it to a repair shop. Water pumps are tricky and if you don’t know what you’re doing you may end up with the same over heating problem.
Add a comment
Add your answer
Tiego Kewele will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 138
