Up to 20% off select tools
A asus asustek monitor is a work monitor which was released in 2022 it has a led screen built in speakers and it’s the perfect office monitor.
How to fix internal screen damage
Hi this monitor has a broken screen internally how can I fix it and what is broken? Pls help!
Score 2
2 Comments
What exactly do you mean by "broken"? A lot of people use it to mean not working, or it can indicate physical damage such as cracks in the screen, so it's important we know your definition. Adding a photo would be a big help so we can see what you see.
Adding images to an existing question
by Share
@dadibrokeit now look at the photo for the. Wiki. Then you will see
by Share
Add a comment
1 Answer
Chosen Solution
@thecat847 Yup, that's a broken screen. Obviously you'll need a new LED panel. Depending on the size of the monitor, it may or may not be cost-effective to repair. Over a certain size, the cost of a replacement part can easily exceed the price of the entire monitor.
However, there's no way of knowing that without the model number. What's yours?
Score 3
Add a comment
Add your answer
The cat15 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 56
All Time: 1,423
