Repair guides for Microsoft's Surface Laptop Go, released in October of 2020.
laptop go 1 : replace existing SSD - wich part?
I have a first-generation Microsoft Surface Laptop Go.
The internal SSD is a 64Gb. I saw that the SSD was removable and replaceable by maximum 256Gb.
Which spare part should I buy?
Do you have any recommendations?
Thanks
Add a comment
1 Answer
According to teardowns and questions around, it uses a replaceable standard NVME M.2 2230 SSD (note that this applies to "Surface Laptop Go", while "Surface Go" has it soldered onboard). Any SSD with these specs and from a reputable manufacturer should be good.
You could try checking a video first: 1, 2
Official replacement guide is here as "Surface Laptop Go Removable SSD English Service Guide"
2 Comments:
@dinoo_fixit Thank you for your reply. Should I get a gen 3 or gen 4 SSD for the first generation surface laptop go?
Thank you
by
The OEM one should be a Gen3, I'd go with the same. Note that you can comment other peoples' replies instead of creating a new reply. Btw have a look at the official replacement guide
by
Add a comment
Add your answer
Raphael Mercier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 268
