Repair guides for Polaroid digital, film, and instant cameras.
Polaroid Snap Touch Firmware Corrupt
Hi,
I bought a Polaroid Snap Touch 1.0 from Zinc (second hand at a pawnshop). After updating the firmware, it got corrupted and all the menus are either invisable or show garbled data as the menu/option buttons (hexadecimal). I tried updating manually via the firmware zip and an sd card, but it either does the same thing or says s/w update failed.
What are my options? I have a CH341A programmer if someone can point out the flash chip. I can dissemble it as well to post picture of the device and mainboard.
Add a comment
1 Answer
Chosen Solution
Hey, sounds like your Snap Touch firmware update went sideways — unfortunately, that’s pretty common with these older Polaroid models. When the menus start showing garbled symbols or hexadecimal-looking text, it usually means the firmware flash got corrupted (either mid-update or due to the wrong version being used).
Here’s what you can try:
  1. Reinstall the firmware cleanly:
    • Reformat your SD card to FAT32.
    • Copy only the official firmware files to it.
    • Make sure the camera battery is fully charged before updating again.
    • Don’t rename the firmware file or remove the battery during the process.
      Sometimes a clean update cycle fixes the corruption.
  2. Manual reflash (using your CH341A):
    Since you’ve got a CH341A programmer, you can go deeper and reflash the firmware directly. Open the camera, find the SPI flash chip (usually an 8-pin IC labeled something like “25Q32” or “25Q64”), and connect your clip to it. You can then dump the current firmware and flash a working image if you can find one online or from another working device.
  3. Double-check firmware versions:
    Polaroid uses hexadecimal versioning, which can be confusing. For example, MM31.00AD.B00 is newer than MM31.0081.B06 — even though it doesn’t look that way at first glance. You can confirm which one’s newer by converting the hex parts to decimal with a quick tool on hexcalculator.org.
If you’re willing to open it up, post some clear photos of the mainboard — especially the area around the memory chips — and folks here can help point out the right chip to program.
Score 2
4 Comments:
Thank you so much for this answer. I do have a programmer and I know how to use it. Unfortunately Polaroid/snap whatever has gone defunct it seems and it's kind of hard to find the firmware but I believe I did find a copy somewhere. I will report back if this works. Thanks for the tips, you seem very knowledgeable,
by
Any update on this issue is much appreciated as I face the same dilemma. The firmware for Snap Touch version 1 is easily available (Snaptouch-1.0-Firmware-2.08) but the it fails consistently. Any luck with CH341A programmer? If so, I'll give it a shot. Btw, the firmware is split between two files and it seems the .bin file is the bootloader and the .brn file is the actual firmware.
by
My snaptouch 1.0 have firmware 2.10 installed and the app try to download 2.08 and the site havee 2,0i as latest firmware, what Is the real latest firmware, Is It possibile that the camera has the latest and the app conidered as latest another firmware?
by
any update? TIA
by
Add a comment
Add your answer
John McAfee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 42
All Time: 550
