Repair documentation for the 3rd generation 11" iPad Pro (model numbers A2377, A2459, A2301, and A2460). Released May 2021.
Battery replacement for m1
Is the ipad pro 2018 and 2020 11inc battery compatible with 2021?
Add a comment
1 Answer
Most Helpful Answer
Over the years battery technology has improved! The iPad Pro 11" (2018) Battery is not as powerful as the iPad Pro 11" (2021, 2022) Battery. So while the batteries do look similar iFixit Store does treat them as different batteries. Also note the 3rd gen battery is a few dollars cheaper!
I would stick with the correct battery.
Here’s the guide iPad Pro 11" 3rd Gen Battery Replacement
Replace a 7869 mAh battery compatible with the 11 inch iPad Pro 2018 model tablet. Fix issues like a swollen or fast draining battery. 3.78 Volts (V). 20.72 Watt Hours (Wh). Battery Model #A2042. Part #020-02875, 020-02507. Image
Product
$49.99
Replace a 7680 mAh battery compatible with the 11 inch iPad Pro 3rd Gen (2021) or 4th Gen (2022) model tablet. Fix issues like a swollen or fast draining battery. 3.76 Volts (V). 29 Watt Hours (Wh). Battery Model #A2369. Image
Product
$49.99
Score 1
Add a comment
Add your answer
Mark laurence will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,006
